Введение
This guide will walk you through the process of opening the Back Panel to your Nvidia Shield Tablet K1.
Выберете то, что вам нужно
Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
Continue lifting up the panel all the way around the edges of the tablet.
Once all of the panel clips are unfastened, gently remove the back panel.
7 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
but wait theres flex cable your not showing thats attached to the cover it could be ripped off and bricked like mine because no one know the name of said cable
