OPPO N1 Headphone Jack and Speaker Cover Replacement
Выберете то, что вам нужно
  1. OPPO N1 Headphone Jack and Speaker Cover Replacement, Rear Case: шаг 1, изображение 1 из 1
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
  2. OPPO N1 Headphone Jack and Speaker Cover Replacement: шаг 2, изображение 1 из 2 OPPO N1 Headphone Jack and Speaker Cover Replacement: шаг 2, изображение 2 из 2
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
  3. OPPO N1 Headphone Jack and Speaker Cover Replacement, Battery: шаг 3, изображение 1 из 2 OPPO N1 Headphone Jack and Speaker Cover Replacement, Battery: шаг 3, изображение 2 из 2
    • Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
  4. OPPO N1 Headphone Jack and Speaker Cover Replacement: шаг 4, изображение 1 из 1
    • Use the tweezers or your fingers to remove the sliver plates.
  5. OPPO N1 Headphone Jack and Speaker Cover Replacement: шаг 5, изображение 1 из 1
    • Remove the black plate with your fingers.
  6. OPPO N1 Headphone Jack and Speaker Cover Replacement: шаг 6, изображение 1 из 3 OPPO N1 Headphone Jack and Speaker Cover Replacement: шаг 6, изображение 2 из 3 OPPO N1 Headphone Jack and Speaker Cover Replacement: шаг 6, изображение 3 из 3
    • Use tweezers or your fingers to pull up the connector tabs.
  7. OPPO N1 Headphone Jack and Speaker Cover Replacement: шаг 7, изображение 1 из 2 OPPO N1 Headphone Jack and Speaker Cover Replacement: шаг 7, изображение 2 из 2
    • Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
  8. OPPO N1 Headphone Jack and Speaker Cover Replacement, Headphone Jack and Speaker Cover: шаг 8, изображение 1 из 1
    • Remove the two 4mm long screws using the ph0 Phillips head screw driver.
    • Remove the six 3mm long screws using the ph0 Phillips head screw driver.
  9. OPPO N1 Headphone Jack and Speaker Cover Replacement: шаг 9, изображение 1 из 2 OPPO N1 Headphone Jack and Speaker Cover Replacement: шаг 9, изображение 2 из 2
    • Use tweezers or your fingers to remove the plastic cover.
Заключение
3 участников успешно повторили данное руководство.
Joshua Stone
Участник с: 09/26/14
1 064 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 13-5, Staggers Fall 2014 Участник USF Tampa, Team 13-5, Staggers Fall 2014
USFT-STAGGERS-F14S13G5
3 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 1,467
