Введение
Have you ever lost those pesky buttons or SIM card trays on the your phone? This guide will help you fix your dilemma.
Выберете то, что вам нужно
Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
The rear case should then come free.
Use tweezers to remove the home button.
In the first photo we rotated the phone 180 degrees. Use tweezers to remove the SIM card tray.
4 участников успешно повторили данное руководство.
