ΠŸΠ΅Ρ€Π΅ΠΉΡ‚ΠΈ ΠΊ основному ΡΠΎΠ΄Π΅Ρ€ΠΆΠ°Π½ΠΈΡŽ
Π’Π²Π΅Π΄Π΅Π½ΠΈΠ΅
After completing the prerequisite guides we will be showing you the step by step process of removing & or disconneting components of the screen.
Π˜Π½ΡΡ‚Ρ€ΡƒΠΌΠ΅Π½Ρ‚Ρ‹
Запчасти
Π”Π΅Ρ‚Π°Π»ΠΈ Π½Π΅ ΡƒΠΊΠ°Π·Π°Π½Ρ‹.
  1. Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
  2. In the photo we rotated the phone ninety degrees counterclockwise. Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
  3. Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver. Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
    • Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
  4. Use the tweezers or your fingers to remove the sliver plates.
    • Use the tweezers or your fingers to remove the sliver plates.
  5. Remove the black plate with your fingers.
    • Remove the black plate with your fingers.
  6. Use tweezers  or your fingers to pull up the connector tabs. Use tweezers  or your fingers to pull up the connector tabs. Use tweezers  or your fingers to pull up the connector tabs.
    • Use tweezers or your fingers to pull up the connector tabs.
  7. Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device. Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
    • Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
  8. Use tweezers or fingers to remove the three connector tabs.
    • Use tweezers or fingers to remove the three connector tabs.
  9. Use tweezers or your fingers to remove the motherboard. Use tweezers or your fingers to remove the motherboard.
    • Use tweezers or your fingers to remove the motherboard.
  10. Remove the two 4mm long screws using the ph0 Phillips head screw driver.
    • Remove the two 4mm long screws using the ph0 Phillips head screw driver.
    • Remove the six 3mm long screws using the ph0 Phillips head screw driver.
  11. Use tweezers or your fingers to remove the plastic cover. Use tweezers or your fingers to remove the plastic cover.
    • Use tweezers or your fingers to remove the plastic cover.
  12. Use tweezers to disconnect the connector tab.
    • Use tweezers to disconnect the connector tab.
  13. Use tweezers to peel the black strip from the sticky tape attached to the phone so that the black strip will slide through the phone once the screen is removed.
    • Use tweezers to peel the black strip from the sticky tape attached to the phone so that the black strip will slide through the phone once the screen is removed.
    • Be gentle removing the black strip at this stage. It can easily tear and it must be removed in order to remove the screen.
  14. Insert the blue opening tool into the crevice between the screen and the main body of the phone. Gently slide the tool around the edge of the phone. Insert the blue opening tool into the crevice between the screen and the main body of the phone. Gently slide the tool around the edge of the phone. Insert the blue opening tool into the crevice between the screen and the main body of the phone. Gently slide the tool around the edge of the phone.
    • Insert the blue opening tool into the crevice between the screen and the main body of the phone. Gently slide the tool around the edge of the phone.
  15. Insert the blue opening tool in between the black screen and the white border and slide it around the edge of the black screen. Insert the blue opening tool in between the black screen and the white border and slide it around the edge of the black screen.
    • Insert the blue opening tool in between the black screen and the white border and slide it around the edge of the black screen.
Π—Π°ΠΊΠ»ΡŽΡ‡Π΅Π½ΠΈΠ΅
10 участников ΡƒΡΠΏΠ΅ΡˆΠ½ΠΎ ΠΏΠΎΠ²Ρ‚ΠΎΡ€ΠΈΠ»ΠΈ Π΄Π°Π½Π½ΠΎΠ΅ руководство.
Joshua Stone
Участник с: 26.09.2014
1Β 034 РСпутация
Автор 5 руководств
Команда
USF Tampa, Team 13-5, Staggers Fall 2014 Участник USF Tampa, Team 13-5, Staggers Fall 2014
USFT-STAGGERS-F14S13G5
3 Ρ‡Π»Π΅Π½ΠΎΠ²
Автор 8 руководств
ΠšΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠ΅Π²: 0
Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
ΠŸΡ€ΠΎΡΠΌΠΎΡ‚Ρ€ статистики:
Π—Π° послСдниС 24часов: 0
Π—Π° послСдниС 7 Π΄Π½Π΅ΠΉ: 9
Π—Π° послСдниС 30 Π΄Π½Π΅ΠΉ: 33
Π—Π° всё врСмя: 4,665
