Введение
This guide will teach you how to disassemble the control box of the Oculus Rift DK1.
Выберете то, что вам нужно
Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
You can now remove the bottom lid of the control box. It should come apart easily.
