Введение
If the device is not working properly this could be due to a broken headset motherboard. Common causes for motherboard failures include being exposed to static shock, overheating, or component failure.
Выберете то, что вам нужно
Remove front cover plate.
Unplug the USB and HDMI cables from the Oculus Rift DK2.
With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures.
Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable.
Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
7 участников успешно повторили данное руководство.
