Olympus Camedia D560 Battery Compartment Cover Replacement
Выберете то, что вам нужно
  1. Olympus Camedia D560 Battery Compartment Cover Replacement, Battery Compartment Cover: шаг 1, изображение 1 из 3 Olympus Camedia D560 Battery Compartment Cover Replacement, Battery Compartment Cover: шаг 1, изображение 2 из 3 Olympus Camedia D560 Battery Compartment Cover Replacement, Battery Compartment Cover: шаг 1, изображение 3 из 3
    • Remove all five screws found on the outer shell of the camera.
    • Three along the bottom
    • Two on the side closest to the LCD screen
    • You will find three more under the USB port flap and one more under the memory card flap. Remove these four as well.
    • Once all screws are removed, use a blue prying tool to carefully pry the back outer shell away from the rest of the camera.
  2. Olympus Camedia D560 Battery Compartment Cover Replacement: шаг 2, изображение 1 из 3 Olympus Camedia D560 Battery Compartment Cover Replacement: шаг 2, изображение 2 из 3 Olympus Camedia D560 Battery Compartment Cover Replacement: шаг 2, изображение 3 из 3
    • Completely separate the back cover from the rest of the camera. Set the back cover aside.
    • Remove four screws from the front outer cover of the camera.
    • Use a Spudger to pry the front outer cover away from the camera. Do this gently to avoid damaging the yellow and black wires connecting the front outer cover to the camera.
  3. Olympus Camedia D560 Battery Compartment Cover Replacement: шаг 3, изображение 1 из 3 Olympus Camedia D560 Battery Compartment Cover Replacement: шаг 3, изображение 2 из 3 Olympus Camedia D560 Battery Compartment Cover Replacement: шаг 3, изображение 3 из 3
    • To remove the yellow and black wires, gently unplug the end of the wire connected to the inner casing of the camera.
    • The front outer cover should now be completely separated from the rest of the camera.
  4. Olympus Camedia D560 Battery Compartment Cover Replacement: шаг 4, изображение 1 из 3 Olympus Camedia D560 Battery Compartment Cover Replacement: шаг 4, изображение 2 из 3 Olympus Camedia D560 Battery Compartment Cover Replacement: шаг 4, изображение 3 из 3
    • Carefully set aside the front outer cover of the camera.
    • Locate and remove the two screws attaching the battery compartment cover to the rest of the camera.
    • Once both screws are removed, the back hinge of the battery compartment cover will flip up.
  5. Olympus Camedia D560 Battery Compartment Cover Replacement: шаг 5, изображение 1 из 1
    • Your battery compartment cover should now be completely removed and ready for repair or replacement.
Заключение
GradStudents2011
Участник с: 09/08/11
21 Репутация
Автор 3 руководств
Команда
University of Maine, Team 1-27, Diaz Fall 2011 Участник University of Maine, Team 1-27, Diaz Fall 2011
UMAINE-DIAZ-F11S1G27
1 член
Автор 3 руководств
Один комментарий
can someone , please, show me how to replace or repair the flashlight of this camera? mine stopped working.
thank you, hendrik
olé kike - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 18
За всё время: 1,560
