Введение
The guide shows how to remove the backplate of the camera. It is a prerequisite to other guides such as replacing the mic, speaker, LCD screen, and lens.
Запчасти
Детали не указаны.
Flip camera so you are looking at the bottom.
Unscrew all 5 base plate screws.
Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
Lift the rubber plate exposing the ports beneath.
Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
Use a phillips head screwdriver to remove the 3 screws highlighted in the picture.
Get a flathead screwdriver or an iPod opening tool (both are shown in this picture).
Carefully pry off the blackplate from the remaining part of the camera.
