Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The guide shows how to remove the backplate of the camera. It is a prerequisite to other guides such as replacing the mic, speaker, LCD screen, and lens.
Выберете то, что вам нужно
Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
Remove the single screw from the battery housing using a Phillips #00 screwdriver.
To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
Use a phillips head screwdriver to remove the 3 screws highlighted in the picture.
Get a flathead screwdriver or an iPod opening tool (both are shown in this picture).
Carefully pry off the blackplate from the remaining part of the camera.
