Введение
This guide shows how to replace the camera lens and surrounding mechanisms (including the motor).
Инструменты
Дополнительные Инструменты
Запчасти
Детали не указаны.
Flip camera so you are looking at the bottom.
Unscrew all 5 base plate screws.
Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
Lift the rubber plate exposing the ports beneath.
Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
Use a phillips head screwdriver to remove the 3 screws highlighted in the picture.
Get a flathead screwdriver or an iPod opening tool (both are shown in this picture).
Carefully pry off the blackplate from the remaining part of the camera.
Remove the side pannel by sliding it off the body of the camera.
Lift the camera no more than 3cm to make sure all screws have been taken off.
Flip camera so you are looking at the front.
Remove gray and blue wiring with tweasers by gently wiggling and pulling.
Locate the tape securing the wiring with the gray end piece located on top of the camera.
Gently lift up on the tape till all wires are exposed.
Flip Camera to the bottom side as shown.
Pull and wriggle the thin yellow wiring tape to detach it from the rest of the camera, while leaving it attached to the LCD screen.
Flip camera so the front is facing you.
Locate speaker in upper right hand corner.
Gently lift with tweasers.
Feed wiring through designated spot so that it is no longer connected to the camera.
Lift the LCD screen so the thick yellow wiring is the only thing attaching the LCD screen to the camera.
Gently pull the thick yellow wiring out by using the forefinger and thumb.
Flip camera so you are looking at the back.
Remove the 3 screws from the rear of the camera behind the lens.
Flip camera over so the lens is facing down and the back of the camera is facing you.
Gently pull back on the wire that connects logic board to lens assembly so it is no longer connected.
Carefully lift lens assembly out of camera.
