Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide shows how to replace a broken retainer clip (the plastic piece that covers the battery and XD card slot).
Выберете то, что вам нужно
Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
Remove the single screw from the battery housing using a Phillips #00 screwdriver.
To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
Orient the camera as shown, with the bottom facing up.
Open the retainer clip, by using your finger to push down and slide to the left.
The clip should pop open.
Hold the retainer clip down (without re-latching it).
Use a flathead screwdriver to start to pry out the pin holding the retainer clip's spring to the camera.
Once the pin comes out, the retainer clip, spring, and pin will no longer be attached to the rest of the camera.
