Введение
This Guide will give step-by-step instructions on how to install a microphone and speaker system into the Olympus D590 camera.
Запчасти
Детали не указаны.
  1. Olympus D590 Speaker and Microphone Replacement, Face Plate: step 1, image 1 of 1
    • Flip camera so you are looking at the bottom.
    • Unscrew all 5 base plate screws.
  2. Olympus D590 Speaker and Microphone Replacement: step 2, image 1 of 1
    • Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
  3. Olympus D590 Speaker and Microphone Replacement: step 3, image 1 of 1
    • Unscrew the single screw located next to the battery slot.
  4. Olympus D590 Speaker and Microphone Replacement: step 4, image 1 of 1
    • Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
    • Lift the rubber plate exposing the ports beneath.
  5. Olympus D590 Speaker and Microphone Replacement: step 5, image 1 of 1
    • Unscrew the 2 screws next to the USB and AC ports.
  6. Olympus D590 Speaker and Microphone Replacement: step 6, image 1 of 1
    • Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
  7. Olympus D590 Speaker and Microphone Replacement: step 7, image 1 of 1
    • Pull off the faceplate to reveal the inside of the camera.
    • Be careful of the connector that goes from the faceplate to the motherboard . Disconnecting this line will cause the camera not not power on through the on/off switch anymore.
  8. Olympus D590 Speaker and Microphone Replacement, Backplate: step 8, image 1 of 1
    • Use a phillips head screwdriver to remove the 3 screws highlighted in the picture.
  9. Olympus D590 Speaker and Microphone Replacement: step 9, image 1 of 1
    • Unscrew the 2 screws located on either side of the flash.
  10. Olympus D590 Speaker and Microphone Replacement: step 10, image 1 of 1
    • Get a flathead screwdriver or an iPod opening tool (both are shown in this picture).
    • Carefully pry off the blackplate from the remaining part of the camera.
  11. Olympus D590 Speaker and Microphone Replacement: step 11, image 1 of 1
    • Pull the backplate off.
  12. Olympus D590 Speaker and Microphone Replacement, LCD screen: step 12, image 1 of 1
    • Unscrew the screw shown in the picture from LCD screen.
  13. Olympus D590 Speaker and Microphone Replacement: step 13, image 1 of 2 Olympus D590 Speaker and Microphone Replacement: step 13, image 2 of 2
    • Remove the side pannel by sliding it off the body of the camera.
    • Lift the camera no more than 3cm to make sure all screws have been taken off.
  14. Olympus D590 Speaker and Microphone Replacement: step 14, image 1 of 2 Olympus D590 Speaker and Microphone Replacement: step 14, image 2 of 2
    • Flip camera so you are looking at the front.
    • Remove gray and blue wiring with tweasers by gently wiggling and pulling.
    • Be careful not to rip the wiring tape with the tweezers.
  15. Olympus D590 Speaker and Microphone Replacement: step 15, image 1 of 2 Olympus D590 Speaker and Microphone Replacement: step 15, image 2 of 2
    • Locate the tape securing the wiring with the gray end piece located on top of the camera.
    • Gently lift up on the tape till all wires are exposed.
  16. Olympus D590 Speaker and Microphone Replacement: step 16, image 1 of 1
    • Flip Camera to the bottom side as shown.
    • Pull and wriggle the thin yellow wiring tape to detach it from the rest of the camera, while leaving it attached to the LCD screen.
  17. Olympus D590 Speaker and Microphone Replacement: step 17, image 1 of 3 Olympus D590 Speaker and Microphone Replacement: step 17, image 2 of 3 Olympus D590 Speaker and Microphone Replacement: step 17, image 3 of 3
    • Flip camera so the front is facing you.
    • Locate speaker in upper right hand corner.
    • Gently lift with tweasers.
    • Feed wiring through designated spot so that it is no longer connected to the camera.
  18. Olympus D590 Speaker and Microphone Replacement: step 18, image 1 of 2 Olympus D590 Speaker and Microphone Replacement: step 18, image 2 of 2
    • Lift the LCD screen so the thick yellow wiring is the only thing attaching the LCD screen to the camera.
    • Gently pull the thick yellow wiring out by using the forefinger and thumb.
  19. Olympus D590 Speaker and Microphone Replacement, Speaker and Microphone: step 19, image 1 of 3 Olympus D590 Speaker and Microphone Replacement, Speaker and Microphone: step 19, image 2 of 3 Olympus D590 Speaker and Microphone Replacement, Speaker and Microphone: step 19, image 3 of 3
    • Locate speaker on the back of the LCD screen.
    • Remove the tape holding the speaker down by lifing with tweesers.
    • Remove speaker from holding dock.
Заключение
Joshua
Участник с: 15.04.2010
7 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 28-23, Regan Spring 2010 Участник Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 членов
Автор 14 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,353
