Введение
This guide will show you how to replace the speaker in the rear panel
Выберете то, что вам нужно
Push the gray tab down, using a spudger if necessary, and the battery will come out.
There are a total of six screws that must be removed using the the #000 Philips screwdriver.
As per picture one: there is one 4.9 mm Philips head screw on the left side of the camera.
As per picture two: on the bottom of the camera, there are three 3.4 mm Philips head screws; these are located on the darker area of the case.
As per picture three: there are two 5.3 mm Philips head screws on the right side, one is beneath the USB cover.
As per picture one: peel back the black strip.
As per picture two: peel back the Copper strip.
As per picture three: peel back the blue tape.
There are four screws that need to be removed using the #000 Philips screwdriver.
Remove the three 3.4 mm screws on the silver panel.
Now remove the 4.3 mm screw located on the green board.
Using a spudger lift up the black retainer tab.
Gently pull out the ribbon cable.
Using your fingers, grab the copper grounding strip and blue and black tape.
Pull these three back at the same time.
Using a #000 Phillips screwdriver remove the four 3.7 mm screws holding the board.
Using a #000 Phillips screwdriver remove the 4.3 mm screw as shown in picture two as well as the clear plastic sheet.
Using a soldering iron and soldering wick desolder the two wires connecting the speaker
Solder in the new speaker. Be sure to match the wire color to the original wire placement.
Один комментарий
Dear Jeffery,
thank you very much for this nice tutorial.
Could you please tell us the part number of the speaker you exchanged?
Can’t see the upper part of the number on the pictures: ???1710
Thank you
Sincerely
Lears
