Выберете то, что вам нужно
Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
Use the spudger or your fingers to remove the outer circuit board from the camera.
Use the spudger to pull the plastic tabs shown off of the motherboard.
Gently pull the plastic piece off of the motherboard.
Use the pointed end of the spudger to release the ribbon cable clasp.
Remove the ribbon cable from the port using the tweezers.
