Введение
Перейти к шагу 1 ↓Is your LCD Screen cracked or unresponsive? Use this guide to replace it and get back to taking awesome photos.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
Выберете то, что Вам нужно
Инструменты
Turn the camera upside down.
Push the grey tab to the right to open the battery compartment.
Pull out the battery.
Use a Phillips #00 screwdriver to remove the three 2.3 mm screws from the base of the LCD screen.
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove the two 2.2 mm Phillips screws located on the back of the LCD screen.
Use tweezers to remove the top LCD bracket.
Use a Phillips #00 screwdriver to remove the four 1.4 mm screws from the back of the LCD screen.
Remove the LCD ribbon cable with a pair of tweezers.
8 человек успешно провели ремонт по этому руководству.
10 Комментарии к руководству
Magnifico
Great Work!!
Where can I buy a replacement LCD screen?
You don't show the final part taking the glass away from outer and the board, as the screen replacements don't come with connector board
@josollis: Thanks for the hint! I got the missing info from the E-P5 LCD exchange instructions (on ifixit).
I have reassembled the unit after replacing the broken Ribbon, however my LCD images are inverted in normal mode not selfie mode. Do anyone know why ?
Thanks in advance
