Введение
You will need a clean, well-lit area, an iFixit repair kit including the specialized screw driver, along with the Phillips #000 bit. We also recommend you have an organization tray in order to keep track of all the screws you will be taking out.
Выберете то, что вам нужно
Using a plastic opening tool, gently lift the retaining flap on the display cable ZIF connector.
Pull the display cable from its socket on the motherboard.
