Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide gives instructions on how to access and remove the lens from the Olympus Stylus 1010. Before proceeding make sure you have removed the case from the Olympus Stylus 1010.
Запчасти
Детали не указаны.
  1. Remove the five Phillips #00 bottom and right side panel screws. Remove the five Phillips #00 bottom and right side panel screws.
    • Remove the five Phillips #00 bottom and right side panel screws.
  2. Remove the right side panel by pulling off the large silver piece.
    • Remove the right side panel by pulling off the large silver piece.
  3. Remove the remaining three Phillips #00 side and front panel screws. Remove the remaining three Phillips #00 side and front panel screws.
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  6. Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  7. Remove the three Phillips #00 screws from the front of the camera. Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side. Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
  8. Using a plastic spudger, lift up the black clips. Still using the plastic spudger, detach the gold connector strip and white connector strip. Using both hands, pull the camera apart into two pieces.
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
  9. Using a plastic spudger, lift up the black clips. Still using the spudger, detach the three gold wire tape connectors from the inside of the camera.
    • Still using the spudger, detach the three gold wire tape connectors from the inside of the camera.
  10. Remove the three  screws from the inside of the camera using a #00 screwdriver.
    • Remove the three screws from the inside of the camera using a #00 screwdriver.
  11. Using your thumb and forefinger, pull the lens piece straight out from the body of the camera. Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
    • Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
Заключение
2 участников успешно повторили данное руководство.
Max McIntyre
Участник с: 21.01.2011
526 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 13-4, Forte Winter 2011 Участник Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
6 членов
Автор 12 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 5,585
