Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Remove the exterior casing by following the steps below to expose the camera's interior components. See the repair guide for further removal instructions.
Выберете то, что вам нужно
Remove the top three T6 screws of the front panel using a 1.5 mm screwdriver.
Remove the three screws on the side of the lens using a Phillips #00 screwdriver.
Remove the loose washer plate from the T6 screw hole using tweezers.
Slowly peel off the seal from beneath the front plate.
Remove the two screws located on the left side of the camera using a Phillips #00 screwdriver.
Remove the two black speaker screws shown in red circles in the first image using a Phillips #00 screwdriver.
After unscrewing the screws from the previous step, lift out the speaker plate when it becomes loose enough.
Open the multi-connector cover shown in the yellow square in the fourth image.
The side panel that covers the multi-connector and the speaker can be detached by sliding the side panel off of the device.
Remove the screw located below the multi-connector cover using a Phillips #00 screwdriver.
Remove the two screws located at the bottom of the camera using a Phillips #00 screwdriver.
Remove the screw inside of the battery and card compartment cover using a Phillips #00 screwdriver.
Remove the two PH00 screws from the interior front cover.
Rotate the interior front plate outwards until the front plate is freed from the back panel to detach the front plate.
Lift out the shutter, the power buttons, and the retaining plate.
Open the AV port door.
Unscrew the four corner screws that hold the front and back halves of the casing together using a Phillips #00 screwdriver.
Release the top holding clip using a plastic spudger or a fingernail.
Slowly unfold the front and back halves of the camera to expose the electrical ribbons.
Detach the narrow copper ribbon by sliding it off of the computer chip using a thumb or a plastic opening tool and a pair of tweezers.
Detach the white ribbon by sliding it off of the back panel using a thumb or plastic opening tool and a pair of tweezers.
Pivot the black plastic strip up using a plastic opening tool and a pair of tweezers. This will lock the wide copper ribbon in place.
Once the black plastic strip releases the wide copper ribbon, detach the wide copper ribbon using a thumb or a pair of tweezers.
The front and back halves of the device can be separated once all three ribbons are disconnected.
