Введение
If your Olympus Stylus 410 no longer functions properly because of a faulty logic board, use this guide to install a new one.
Выберете то, что вам нужно
Locate the 2 screws on the bottom of the slider.
Remove both screws with a #00 Phillips screwdriver.
Gently pull on the bottom of the slider until it comes off the lower track.
There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
The shutter button can now be removed. It is not connected to the camera and can be lifted off.
Remove the memory card.
Locate and remove the 2 screws using a #00 Phillips screwdriver.
Use a spudger around the edge of the case to loosen it.
Carefully wiggle the back case off. This may require a fair amount of force.
Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
Be careful not to completely pull the front case off because it will still be connected with wires.
