Введение
Use this guide to replace a broken lens inside the camera.
Выберете то, что вам нужно
Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
Detach the ribbons using your thumb, sliding them out of their slots.
Set the back panel face up to keep the ribbons from touching anything.
Remove the top screws using a 1.5 mm screwdriver.
Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
Remove four metal tabs from corners where the 2mm long screws were attached using tweezers.
Remove the viewfinder lens using a prying device.
There will be two ribbons attached to the viewfinder. Remove the ribbons by sliding them off the viewfinder with your thumb.
