Введение
I will be providing clear and easy steps on how to replace your Lens Cover on your Olympus Stylus Tough-6000 Digital Camera.
Запчасти
Никакие детали не требуются.
  1. You will want to disassemble the camera to get to the Lens Cover.
    • You will want to disassemble the camera to get to the Lens Cover.
  2. There are two screws on the right side of the camera.
    • There are two screws on the right side of the camera.
    • Use your Phillips #00 screwdriver and unscrew both screws.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. On the left side of the camera there will be another set of screws.
    • On the left side of the camera there will be another set of screws.
    • Unscrew both screws with the same Phillips #00 screwdriver.
  5. After unscrewing the screws on the left side of the camera you will notice a speaker hat.
    • After unscrewing the screws on the left side of the camera you will notice a speaker hat.
    • You will be able to pull the speaker hat off.
    • You must pull the speaker hat off to be able to pry the front shell of the camera apart.
  6. Grab your plastic opening tool and begin to pry off the front shell of the camera.
    • Grab your plastic opening tool and begin to pry off the front shell of the camera.
    • The front shell will easily come off after a couple of prys.
  7. Once you have the camera shell cover off you can see the lens cover.
    • Once you have the camera shell cover off you can see the lens cover.
    • Unscrew the lens cover with your Phillips #00 screwdriver to replace it with a new lens cover.
Заключение
Shannon Cooney
Участник с: 15.01.2015
328 Репутация
Автор 3 руководств
Команда
USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015 Member of USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015
USFSM-STEWART-W15S1G1
4 членов
Автор 4 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 5
За 30 дней: 5
За всё время: 612
