Olympus Stylus Tough-8010 Lens Replacement
Выберете то, что вам нужно
  1. Olympus Stylus Tough-8010 Lens Replacement, Camera Casing: шаг 1, изображение 1 из 3 Olympus Stylus Tough-8010 Lens Replacement, Camera Casing: шаг 1, изображение 2 из 3 Olympus Stylus Tough-8010 Lens Replacement, Camera Casing: шаг 1, изображение 3 из 3
    • Remove the front three screws (3.2mm) using a type T-6 head screwdriver.
    • Take off smaller front cover.
    • Carefully remove larger front cover.
  2. Olympus Stylus Tough-8010 Lens Replacement: шаг 2, изображение 1 из 3 Olympus Stylus Tough-8010 Lens Replacement: шаг 2, изображение 2 из 3 Olympus Stylus Tough-8010 Lens Replacement: шаг 2, изображение 3 из 3
    • Remove two screws (4.1mm) on the top of the camera using a #000 Phillips head screwdriver.
    • Using a #000 Phillips head screwdriver remove two screws (7.9mm) near the control panel and set aside the metal connector.
    • Although the third photo shows the side panel casing being removed, it is normally secured by a screw under the front framework. You'll need to follow the next two steps to remove the framework and access the screw before you can remove the side casing as shown here.
    NOTE: you cannot remove the side piece until you complete steps 3 and 4 because there's a screw holding the corner of it which you can't see until you remove the front framework. You can just let the side piece hang there while you do that.
    winntom - Ответить
  3. Olympus Stylus Tough-8010 Lens Replacement: шаг 3, изображение 1 из 3 Olympus Stylus Tough-8010 Lens Replacement: шаг 3, изображение 2 из 3 Olympus Stylus Tough-8010 Lens Replacement: шаг 3, изображение 3 из 3
    • Using a #000 Philips head screwdriver remove the two screws (4.1mm) on the right side of the camera.
    • Remove two screws (4.1mm) on the bottom of the camera using a #000 head Phillips screwdriver.
    • Remove the single screw (3.2mm) on the front of the camera using a #000 Phillips head.
  4. Olympus Stylus Tough-8010 Lens Replacement: шаг 4, изображение 1 из 2 Olympus Stylus Tough-8010 Lens Replacement: шаг 4, изображение 2 из 2
    • Carefully remove the font panel piece from the rest of the camera.
    • Carefully remove the top/side plastic piece.
    • If the the camera and flash buttons fall out of their slots set them aside.
    • If you haven't already done so, remove the side casing as mentioned in Step 3. It is secured by a single screw near the bottom corner.
  5. Olympus Stylus Tough-8010 Lens Replacement: шаг 5, изображение 1 из 3 Olympus Stylus Tough-8010 Lens Replacement: шаг 5, изображение 2 из 3 Olympus Stylus Tough-8010 Lens Replacement: шаг 5, изображение 3 из 3
    • Remove four screws (9.4mm) on the front of the camera using a Phillips #000
    • Use the plastic opening tool to release the holding clip.
    • Using tweezers separate the plastic strips from their connectors located on the main circuit board by lifting the small, black flaps on the connectors and pulling on the ribbons.
  6. Olympus Stylus Tough-8010 Lens Replacement, Lens: шаг 6, изображение 1 из 2 Olympus Stylus Tough-8010 Lens Replacement, Lens: шаг 6, изображение 2 из 2
    • Remove any tape on the flash component on the left.
    • Using tweezers, disconnect the plastic strip from its connector on the motherboard by lifting the plastic black flap on the connector and pulling the ribbon.
    • Using a #000 Philips head screwdriver remove four screws (4.1mm) on the metal plate.
    • Gently lift the flash components out of the camera casing.
Заключение
Luke Visser
Участник с: 03/23/15
476 Репутация
Автор 4 руководств
Команда
Baylor, Team 7-15, Williams Spring 2015 Участник Baylor, Team 7-15, Williams Spring 2015
BU-WILLIAMS-S15S7G15
3 членов
Автор 12 руководств
Один комментарий
Hi Luke
DO you know where we can purchase new lens module from
Ian
ian5york - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 8
За всё время: 602
