Введение
Use this guide to remove the side panel of the Olympus Stylus Tough-8010 camera.
Выберете то, что вам нужно
Remove the three screws (3.2mm) from the front panel using a T-6 screwdriver.
Take off the smaller front panel cover.
Carefully remove the larger front cover.
Remove the top two screws (4.1mm) using a #000 Phillips head screwdriver.
Remove the two screws (7.9mm) near the control pad. Set metal connector aside.
Remove the side panel casing.
Using a #000 Philips head screwdriver, remove the two screws (4.1mm) on the right side of the camera.
Remove the two screws (4.1mm) from the bottom of the camera.
Remove the single screw (3.2mm) from the front of the camera.
Carefully remove the front panel piece.
Remove the screw (7.9mm) from the bottom left hand corner using a #000 Phillips head screwdriver.
Slightly bend the metal that is covering the side panel axle.
Using a paperclip, completely push out the metal bar that holds the side panel to the camera.
Remove the side panel door.
