Введение
This guide will show you how to remove the camera's power button so you can replace it if it is not working.
Выберете то, что вам нужно
Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
Use the plastic opening tools and your fingers to pry the front plate from the camera.
Flip the silver panel over. The power button is the smaller button covered by a metal backing.
2 участников успешно повторили данное руководство.
