Введение
When using the metal spudger to remove the battery, be sure to carefully pry along the entire side the battery so that the battery will come off without bending.
Выберете то, что вам нужно
Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover.
3 участников успешно повторили данное руководство.
