Введение
If you are going to replace any of the components in the One Education Infinity, you will need to remove the back case first. After removing the back case, remove the battery as a safety precaution to prevent the risk of electric shock as you work on your device (even if you are only replacing the display assembly).
Выберете то, что вам нужно
Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
Lift the back case off of the device.
