Введение
If your OneLink Safe and Sound device is in need of replacement, follow this step-by-step speaker replacement guide.
Please follow all steps to successfully disassemble the speakers for a seamless replacement.
Выберете то, что вам нужно
Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
Remove plastic rim.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers or a spudger to disconnect the ribbon from the motherboard.
Use the plastic opening tool to remove the microphone connection from the motherboard.
Remove the top of the device.
Use the plastic opening tool to disconnect the cable from the motherboard.
Use a Phillips #0 screwdriver to remove the single screw securing the plastic battery cage.
Remove the plastic cage holding the battery in place.
Remove the battery from the device.
Use the opening tool to disconnect the Wi-Fi cable from the Bluetooth module.
Use the opening tool to disconnect the speaker cables from the daughterboard.
Use the opening to lift the daughterboard off of the motherboard.
Use a Phillips #0 screwdriver to remove seven screws securing the white base and motherboard.
Remove the speaker cables from the channels along the edge of the speaker cover.
Use an opening tool or your fingers to lift the speaker cover off of the back cover which houses the speakers.
