Введение
This guide shows how to remove and replace the rear-facing camera for the OnePlus 3.
Due to the phone’s design, you have to loosen/remove the motherboard in order to remove the rear-facing camera. The hardest part of the guide is getting the frame clips of the back cover free.
Some guide images will show the battery already removed from the phone. You do not need to remove the battery for the rear-facing camera procedure.
Выберете то, что вам нужно
Insert a SIM eject tool, bit, or straightened paperclip into the hole located between the SIM card slot and the power button.
Press firmly to eject the SIM card tray.
Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
Frame seam: This is where the plastic frame meets the back cover. It is recessed into the back cover. Only pry at this seam.
There are fourteen clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
Place a suction cup near the bottom edge of the display.
Pull on the suction cup with strong steady force.
Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
Continue sliding the opening tool along the long edge, releasing the clips along the way.
With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
Lift the screen up and remove it.
Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
Squeeze along the long edges of the phone to snap the remaining clips into place.
Use the point of a spudger to pry up and disconnect the battery connector from its socket, located above the top right corner of the battery pack.
Bend the connector away from the socket to prevent accidental contact.
Remove the 3 mm Phillips screw securing the cable bracket.
Remove the cable bracket.
Use the point of a spudger to pry up and disconnect the interconnect flex cable from the motherboard, which is located above the battery.
Repeat the process to disconnect the daughterboard flex cable from the motherboard.
Slide the point of a spudger underneath the antenna interconnect cable located at the bottom left corner of the motherboard.
Pry up and disconnect the antenna interconnect cable.
Use the point of a spudger to pry up and disconnect the display connector from its socket on the motherboard.
Remove the seven Phillips screws securing the motherboard to the frame:
Four 3 mm black screws
Three 2.9 mm silver screws
The motherboard is still held in place near the top by clips.
Slide the flat end of a spudger underneath the top left corner of the motherboard.
Twist the spudger and pry up to release the motherboard from its recess.
Use the point of a spudger to pry up and disconnect the rear-facing camera connector from its motherboard socket.
Remove the rear-facing camera.
If your replacement part did not come with a black cover, carefully peel the cover off from your old camera and transfer it to your replacement part.
Repair didn’t go as planned? Check out our OnePlus 3 Answers community for troubleshooting help.
48 участников успешно повторили данное руководство.
18 Комментариев
Why do I have to take out the MoBo? For me it looks like the camera connector is accessible without removing everything, one less step to swap screws etc...
I haven't done this procedure yet, but it looks like there is a metal tab that protrudes from the top of the camera module that is tucked under the PCB.
Fantastic! Many thanks. That fixed the problem: no more blurry rear camera. For less than 9 €… You’re the boss!!!
under 10 bucks finally fixed my broken auto focus, great tutorial!
It worked pretty well for me, but I had to use a metal 0.3mm Guitar Pick for the very first opening step, as neither the plastic opening tools nor plastic picks worked for me.
@jackhutchinson60: The back cover is taken off first (which has no eletrical connections) and then the motherboard is removed, but it’s all screws and plugs, so no problem there. According to youtube lens cover fixes are cheap and doable as well.
