OnePlus 3 USB Type-C Port Replacement
Выберете то, что вам нужно
Видеоинструкции
Заключение
25 участников успешно повторили данное руководство.
Witrigs
Участник с: 11/24/15
69 454 Репутация
Автор 378 руководств
14 Комментариев
I broke 5 spudgers getting the screen to separate from the back because dirt had built up around the edge this is also the reason the usb port died. consider buying extra spudgers when doing your repair.
RayZ fox - Ответить
consider keeping your phone clean.
MO MOBILE - Ответить
Is the same charging port used on the 3T?
thisisian - Ответить
I successfully followed this guide, to replace the charging port on an UK 3T phone (it seems like the same part, I bought it on ebay).
The hardest part was getting the first spudger into the phone case, which took me at least 20 minutes (first time trying this). As noted make sure you have spares.
I had a little trouble reconnecting the lower round gold power connector as the cable had shifted a bit during taking out the component it connects to and it was very sensitive to position to go in right.
Having the high quality driver set from ifixit made a huge difference as I’d have spent ages fiddling if the driver was not magnetized for lifting the tiny screws in and out.
Steve -
Perfect ! +-20 min. just be sure to check the rubber of the charging port and aux cable are in the right position before placing the cover back
Yorgi D'Haese - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 25,252
