Введение
The OnePlus 5 has a small daughterboard that mainly houses contact points that connect to loudspeaker and charging assemblies. If you are experiencing issues with any of the functions housed in the bottom half of your phone (e.g., microphone, loudspeaker, charging port) follow this guide to replace the daughterboard in your OnePlus 5. The hardest part of this guide is getting the frame clips of the back cover free to access the internals.
Some guide images will show the battery already removed from the phone. You do not need to remove the battery for the daughterboard procedure.
Выберете то, что вам нужно
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
Press firmly to eject the tray.
Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
What are the reference of the screws ? They are missing in the one I bought !
Hi Yôken,
They help hold the back cover on. Most of the time, the clips are enough to hold the phone together.
Just FYI, for whatever reason my brand new OnePlus 5 had 0,8 mm stars screws instead of T2 Torx.
Definitely T2 for me. Do watch out during assembly. I have a feeling that it’s easy to strip these.
T2 for me too. It was missing in my kit and iFixit sent it later when I asked them about it.
Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
Place a suction cup near the bottom edge of the display.
Pull on the suction cup with strong steady force.
Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
I found the suction cup to be more of a hindrance and kept hitting the power button, making it necessary to stop and turn the phone off again. I watched a youtube video where the person didn't use a suction cup at all and decided to try that. I also found that a guitar pick type spudger worked far better than the one shown in the picture. If you're having trouble getting it started, I suggest trying those two things.
Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
This was extremely difficult & took a lot of force. I needed a thin flat metal spudger and wrecked a couple of plastic ones in the process. I left a few scratches along the join in the process. It would be easier if I had something to hold the phone, in my hand I kept turning it on by accident.
what was the metal spudger did you use? I am having trouble as well. I cannot seem to pry the back cover and it feels like it is shut tightly, there are no crevices I can pry into. What was your strategy may I ask?
At first, I slightly opened the body with a plastic tool, but it was not enough to actually open the back cover. Then I used a thin metal screwdriver for this. It was difficult but nothing special. Just be sure that you are opening the correct seam between the body and the screen and don’t make sudden moves. I bent nothing, everything came back in place when reassembled.
ivan -
Same as David here: the plastic opening tools/guitar picks were doing nothing (not even creating the first "crack") . In the end I managed to open it using Jimmy (the metal knife/spudger), but not without scratching the whole metal cover.
Continue sliding the opening tool along the long edge, releasing the clips along the way.
With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
Squeeze along the long edges of the phone to snap the remaining clips into place.
Reinstalling the back cover stumped me for a second… If you’re struggling with aligning the top edge of the frame, remember that the camera is going to look off/pointed a bit too low until you actually clip the frame back in.
Really stupid but it was the only thing that tripped me up in this guide.
With all the clips released, flip the phone over so that the display is face-down.
Swing the back cover around and rest it on top of the exposed frame.
Remove the 2.6 mm Phillips screw holding the cable bracket above the battery in place.
Lift up and remove the cable bracket.
Use the point of a spudger to pry up and disconnect the back cover flex cable from its socket.
If the flex cable pins are damaged, the flex cable can be replaced.
If the connecter pins (on the motherboard) are damaged, you might need to do microsoldering (or contact a microsoldering company) to replace the damaged connector.
Brendan -
Use the point of a spudger to pry up and disconnect the battery connector from its socket.
Remove the six 2.6 mm Phillips screws securing the loudspeaker to the frame.
Insert the flat end of a spudger into the corner of the loudspeaker assembly and pry slightly, loosening the loudspeaker from its recess.
Use the point of a spudger to pry up and disconnect the interconnect flex cable from the socket.
This step is used in multiple guides, and not all of them require the cable to be bent away. You can just leave it sitting there, disconnected.
This image seems to show the daughterboard removed but there is no corresponding previous step. I see no way to remove the interconnect flex cable without removing the daughterboard. Possibly the volume switch can be removed with the cable still connected but I'm not confident enough to try this so will remove the daughterboard.
David,
Thanks for bringing this up. That's indeed a procedural error! I've added the missing steps in the affected guides.
Use the point of a spudger the pry up and disconnect the fingerprint scanner connector from its socket on the daughterboard.
Slip the point of a spudger underneath the antenna interconnect cable and pry up to disconnect it from its socket on the daughterboard.
De-route the antenna interconnect cable out of the way of the daughterboard.
Insert the edge of a flat end of the spudger underneath the microphone board and twist slightly to release the board's adhesive.
Slide the flat end of a spudger or the point of an opening pick underneath the daughterboard near its right edge.
Gently pry to loosen the daughterboard from its recess.
Insert the flat end of a spudger underneath the daughterboard, this time approaching it from the bottom.
Twist and slide the spudger slightly to release the daughterboard from its recess.
Repair didn’t go as planned? Check out our OnePlus 5 Answers Community for troubleshooting help.
Еще один человек закончил это руководство.
