OnePlus 6T Back Cover Replacement
Выберете то, что вам нужно
  1. OnePlus 6T Back Cover Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
  2. OnePlus 6T Back Cover Replacement: шаг 2, изображение 1 из 1
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
  3. OnePlus 6T Back Cover Replacement: шаг 3, изображение 1 из 1
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
  4. OnePlus 6T Back Cover Replacement: шаг 4, изображение 1 из 3 OnePlus 6T Back Cover Replacement: шаг 4, изображение 2 из 3 OnePlus 6T Back Cover Replacement: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    Купить
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
Заключение
17 участников успешно повторили данное руководство.
Kira D'Agostino
Участник с: 10/15/19
1 498 Репутация
Автор 2 руководств
Команда
Grand Valley State University, Team S4-G6, DeVasto Fall 2019 Участник Grand Valley State University, Team S4-G6, DeVasto Fall 2019
GVSU-DEVASTO-F19S4G6
4 членов
Автор 19 руководств
3 Комментариев
I wonder if this is the same for OnePlus 6 (6000/6003)?
karlkristians - Ответить
another greath guide, repaird check.
In same time rplacd the battery so phone is ready for another few years
yoeri - Ответить
Thanks for this guide. But is there something particular after removing the old piece to install the new one ? How the new one will be glued ?
Alexandre Herbreteau - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 35
За последние 30 дней: 155
За всё время: 18,227
