Введение
Use this guide to replace a broken or cracked OnePlus 6T Front Camera.
Выберете то, что вам нужно
Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
Carefully remove the SIM card from its tray.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
Remove the back cover from the phone.
Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
Use tweezers to remove the battery cover and place it to the side.
Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
Remove the front camera from the phone.
2 участников успешно повторили данное руководство.
