OnePlus 6T Speaker Replacement
Выберете то, что вам нужно
  1. OnePlus 6T Speaker Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
  2. OnePlus 6T Speaker Replacement: шаг 2, изображение 1 из 1
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
  3. OnePlus 6T Speaker Replacement: шаг 3, изображение 1 из 1
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
  4. OnePlus 6T Speaker Replacement: шаг 4, изображение 1 из 3 OnePlus 6T Speaker Replacement: шаг 4, изображение 2 из 3 OnePlus 6T Speaker Replacement: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    Купить
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
  5. OnePlus 6T Speaker Replacement, Speaker: шаг 5, изображение 1 из 1
    • Remove seven 3mm Phillips #00 screws from the speaker.
  6. OnePlus 6T Speaker Replacement: шаг 6, изображение 1 из 1
    • Use a spudger to lift and remove the speaker.
Заключение
7 участников успешно повторили данное руководство.
Quinn Jones
Участник с: 10/15/19
172 Репутация
1 руководство автора
Команда
Grand Valley State University, Team S4-G6, DeVasto Fall 2019 Участник Grand Valley State University, Team S4-G6, DeVasto Fall 2019
GVSU-DEVASTO-F19S4G6
4 членов
Автор 19 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 11
За последние 30 дней: 61
За всё время: 3,436
