Введение
Use this guide to replace a battery cover on your OnePlus 7 Pro smartphone.
Before disassembling your device, be sure the battery is charged below 25%. If accidentally punctured or damaged, the battery can catch fire and/or explode; if discharged below 25%, the chances of fire/explosion is decreased.
Be sure to power off the device before beginning the disassembly process.
Follow the iOpener Heating guide for instructions on using the iOpener.
Выберете то, что вам нужно
Видеообзор
OnePlus 7 Pro Battery Cover Replacement
Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
Press gently to eject the SIM tray.
Remove the SIM card tray from the device.
Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Apply a suction cup to the lower portion of the phone's backing and pull firmly to create a crack between the back cover and the rest of the phone.
Insert a Jimmy tool, opening pick, or plastic card under the edge of the back cover.
Use a plastic card or Jimmy tool to slice around the phone's seam, cutting through the adhesive.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a pair of tweezers to lift up the piece of black tape covering the laser autofocus and flash flex cable.
Use a pair of tweezers to lift and remove the covering on the laser autofocus and flash flex cable.
Use the flat end of a spudger to disconnect the laser autofocus and flash flex cable.
To reassemble your device, replace the battery cover and follow these instructions in reverse order.
9 человек успешно провели ремонт по этому руководству.
