OnePlus 9 Pro Rear Glass Replacement
Выберете то, что вам нужно
  1. OnePlus 9 Pro Rear Glass Replacement, Rear Glass: шаг 1, изображение 1 из 1
    • For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
    • Unplug any chargers/peripheries and power off your phone.
  2. OnePlus 9 Pro Rear Glass Replacement: шаг 2, изображение 1 из 1
  3. OnePlus 9 Pro Rear Glass Replacement: шаг 3, изображение 1 из 2 OnePlus 9 Pro Rear Glass Replacement: шаг 3, изображение 2 из 2
    • Use a hair dryer to lightly heat the perimeter of the rear glass.
    • Additionally, heat the top-right corner, as there is adhesive further inside of phone in that one spot.
    • Do not hold the hair dryer in one spot on the phone for too long to prevent damage to internal parts of the phone.
  4. OnePlus 9 Pro Rear Glass Replacement: шаг 4, изображение 1 из 1
    • Apply a suction handle as close to the bottom edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the glass and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive.
    • Insert an opening pick into the gap.
  5. OnePlus 9 Pro Rear Glass Replacement: шаг 5, изображение 1 из 1
    • Slide the opening pick around the perimeter of the rear glass to slice the adhesive.
    • Insert additional opening picks as you slice the adhesive to prevent the adhesive from resealing.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your hair dryer to reheat it.
  6. OnePlus 9 Pro Rear Glass Replacement: шаг 6, изображение 1 из 2 OnePlus 9 Pro Rear Glass Replacement: шаг 6, изображение 2 из 2
    • Carefully lift the rear glass up and off of the phone.
    • During reassembly secure the rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Averie
Участник с: 02/17/25
273 Репутация
Автор 2 руководств
Команда
University of Memphis, Team 1-1, Sneed Spring 2025 Участник University of Memphis, Team 1-1, Sneed Spring 2025
UM-SNEED-S25S1G1
4 членов
Автор 9 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 14
За последние 30 дней: 76
За всё время: 616
