Выберете то, что вам нужно
Take sim tray out prior to beginning repair.
Heat back of phone to make the adhesion more pliable
Insert a slim prying tool to begin removing the back cover, move in a counterclockwise direction
Add IPA as you work to detatch the adhesion layer
When approaching the volume button, be cautious, as the ribbon cable is exposed and can easilyt be cut
Remove back cover
Using a J000 screwdriver, remove the Screws holding the edge casing to the screen (19 Total)
Using a pry tool, seperate the edge plastic from the screen
Once you have attained suitable lift, disconnect the power button cable.
Remove the edge plastic and set aside.
Remove the plastic speaker piece
Disconnect the antenna cables and main board connector
Remove the board and insert new component
reconnect connectors
Reconnect the antenna and main board
Reconnect the power cable, and reattach the plastic edge
Using J000, screw the 19 screws back in
Reconnect the back plastic, and set on heat to adhere
You can also use tesa tape to increase the adhesion.
This order can be used for charger, headphone jack, or water damage to sub board.
