Введение
Use this guide to replace a damaged rear glass on your OnePlus Nord.
You’ll need replacement adhesive to reattach components when reassembling the device.
Выберете то, что вам нужно
Switch off your phone.
Heat an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. If you have a heatbed with precise temperature control (like any FDM 3D printer with heatbed) 45°C is enough. You might want to repeat this step several times during the rear glass removal.
Apply a suction cup to the back of the phone, as close as possible to the center of the right edge.
Pull on the suction cup to create a gap between the rear glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the edge to the bottom right corner.
Leave the opening pick in its place to prevent the adhesive from resealing.
Insert a second opening pick under the bottom right corner.
Slide the opening pick along the edge to the top right corner.
Insert a third opening pick under the top right corner of the back cover.
Slide the tip of the opening pick along the edge of the phone to the top left corner to cut the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick under the top left corner.
Slide the opening pick along the edge to the bottom left corner to cut the adhesive.
Insert a fifth opening pick under the bottom left corner.
Slide it along the the edge to the bottom right corner to cut the remaining adhesive.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Еще один человек закончил это руководство.
