OnePlus One Battery Replacement
Выберете то, что вам нужно
  1. OnePlus One Battery Replacement, Battery: шаг 1, изображение 1 из 3 OnePlus One Battery Replacement, Battery: шаг 1, изображение 2 из 3 OnePlus One Battery Replacement, Battery: шаг 1, изображение 3 из 3
    • Remove the SIM tray.
    • Using a plastic opening tool, carefully separate the back panel from the main body assembly of the phone. Be extra careful around the SIM slot or other weak areas.
    • You may encounter some resistance due to hidden locking clips around the inside edge of the phone. Not to worry; just move in one consistent direction around the phone as opposed to jumping from spot to spot!
    • Top to bottom, left to right, clockwise or counter clockwise, once we make it about half way around the device, the panel is easily removable by hand.
    • It is of utmost importance that you do not attempt to free the battery from the device at this point without proceeding to the following step! This is an integrated battery that can easily be damaged or destroyed if the proper steps are are not taken.
  2. OnePlus One Battery Replacement: шаг 2, изображение 1 из 3 OnePlus One Battery Replacement: шаг 2, изображение 2 из 3 OnePlus One Battery Replacement: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Using a pair of tweezers, remove the plastic plugs.
    • Once the hidden screws are revealed, use a PH #00 screwdriver to remove the three 3.175mm screws.
    • Use the PH #00 screwdriver to remove the remaining six 3.175 screws.
  3. OnePlus One Battery Replacement: шаг 3, изображение 1 из 1
    • Using a plastic opening tool, gently pry up the black plastic cover and remove it from the device.
  4. OnePlus One Battery Replacement: шаг 4, изображение 1 из 3 OnePlus One Battery Replacement: шаг 4, изображение 2 из 3 OnePlus One Battery Replacement: шаг 4, изображение 3 из 3
    • After we have removed the motherboard cover, we notice that the battery is intact and has a black ribbon attached to it, which is mounted on the logic board.
    • Using the spudger, carefully begin to lift the the battery up from the side opposite the ribbon. Be aware that there is high-grade adhesive holding the battery in its bay, so proceed with caution.
    • This battery is not encased in a hard shell so it is soft and malleable. Caution must be taken during removal so as not to cause permanent damage.
  5. OnePlus One Battery Replacement: шаг 5, изображение 1 из 3 OnePlus One Battery Replacement: шаг 5, изображение 2 из 3 OnePlus One Battery Replacement: шаг 5, изображение 3 из 3
    • Once the battery has been freed, we use the ever handy black spudger to pry up and free the battery ribbon from its dock.
    • You can disconnect the battery before freeing it to make removal easier.
Заключение
201 человек успешно провели ремонт по этому руководству.
Javier Cruz
Участник с: 09/22/14
2 292 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 3-3, Brown Fall 2014 Участник USF Tampa, Team 3-3, Brown Fall 2014
USFT-BROWN-F14S3G3
3 членов
Автор 20 руководств
36 Комментарии к руководству
The Apple iPhone sim ejector is not long enough to work on an OPO. A paper clip is a better option.
stephenacook - Ответить
There will be a compatible battery with one pin OnePlus
Gendarmetal Rock - Ответить
Successfully accomplished, thanks to your clear instructions. One note: the adhesive on my unit was applied in about a quarter inch strip along the right underside of the battery as you view it from the back. Peeling up the left side allowed me to reach and release the adhesive on the opposite side with the spudger or knife blade.
That Guy - Ответить
Thank you! I use a slim (but not sharp) butter knife to nudge the battery out slowly by poking the adhesive tape along its length. It was a bit unnerving because I was afraid of damaging the soft battery. Worked out in the end.
Benoit Hogue -
One note to add is that the original battery connector's top was glued to the motherboard cover. I had to remove the battery before I could successfully sepearte the 2. My phone is still working and I'm charging it right now! :)
Thanks for the very detailed guide.
Benoit Hogue -
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 79
За последние 30 дней: 393
За всё время: 220,090
