OnePlus One Display Assembly Replacement
Выберете то, что вам нужно
  1. OnePlus One Display Assembly Replacement, Battery: шаг 1, изображение 1 из 3 OnePlus One Display Assembly Replacement, Battery: шаг 1, изображение 2 из 3 OnePlus One Display Assembly Replacement, Battery: шаг 1, изображение 3 из 3
    • Remove the SIM tray.
    • Using a plastic opening tool, carefully separate the back panel from the main body assembly of the phone. Be extra careful around the SIM slot or other weak areas.
    • You may encounter some resistance due to hidden locking clips around the inside edge of the phone. Not to worry; just move in one consistent direction around the phone as opposed to jumping from spot to spot!
    • Top to bottom, left to right, clockwise or counter clockwise, once we make it about half way around the device, the panel is easily removable by hand.
    • It is of utmost importance that you do not attempt to free the battery from the device at this point without proceeding to the following step! This is an integrated battery that can easily be damaged or destroyed if the proper steps are are not taken.
    It doesn't mention you have to remove SIM tray first.
    pawel - Ответить
    I used the #0 for the rear panel screws. The #00 is too small and will slip, stripping the screws if you're not extra careful.
    anonymous 2668 - Ответить
    where can i buy the battery??
    Shaun Davis - Ответить
    Has anyone answered this? I am looking too.
    Elie Daou -
    They sell it on here, although I found mine on eBay.
    Roger -
    Aliexpress for $9 (original)
    David van Ballegooijen -
    The last three hidden screws are a !&&* of a time consumer to remove. probably you would need only a certain type of tweezers - I got stuck at midway and now I cannot get go have my phone detect the sim card either probably because the six screws are removed. I can now turn the phone back on but with no service or wifi connections are detected. This phone is a disaster!
    Manan Shah - Ответить
    Ivdid that too but son in law found I had reinstalled sim card in backwards or upside down.
    wildcat75666 -
    Where did you buy the micro USB piece? Thanks a lot!
    Davide Rota - Ответить
    EBay. I bought new battery cause old ibe was dead would not charge. Just ordered new cables fit 9.00 something free shipping. Anyway hope this fixes problem cause new battery did not fix problems.
    wildcat75666 -
    I was able to open going from the microusb slot and working my way around. The corners are tough, though.
    Roger - Ответить
    in my phone the battery was glued with double sided adhesive tape, only on the right side. I pried the left side up first, and carefully removed the battery. to lift the battery I used first used a suction cup(?) followed by a plectrum like tool to lift te battery, and keep it lifted
    Eelco Busch - Ответить
    A word of caution: the back panel is harder to remove than you might think. Especially because you may be removing the *screen* by mistake. When you have a "grip" with the tool make sure the metallic border is not coming off with it, and when you have removed enough to be able to lift the panel, make sure it isn't attached by ribbons - in that case you've been removing the screen. A good idea is to gently press your finger nail against the weak plastic located between the back and the SIM slot, and going up and down and sideways until you hear a click. Then you can start from there with the opening tool. As recommended be very gentle around the SIM slot.
    Menahem Julien Raccah Lisei - Ответить
    Where do I get the plastic opening tool?
    Julie Hejducek - Ответить
  2. OnePlus One Display Assembly Replacement: шаг 2, изображение 1 из 3 OnePlus One Display Assembly Replacement: шаг 2, изображение 2 из 3 OnePlus One Display Assembly Replacement: шаг 2, изображение 3 из 3
    • Using a pair of tweezers, remove the plastic plugs.
    • Once the hidden screws are revealed, use a PH #00 screwdriver to remove the three 3.175mm screws.
    • Use the PH #00 screwdriver to remove the remaining six 3.175 screws.
    The plugs are annoying to open for the first time. They're shaped like little pegs, but I was able to poke at them with screwdrivers enough to open.
    Roger - Ответить
    the best spot to start prying the cover open is at the cable outlet for the power/volume buttons (careful not to dameage the wires)
    Marius137 - Ответить
    A needle works best to remove the plugs.
    Stan Barton - Ответить
    I second this. I used a sewing pin and the plugs came out in no time!
    Liam Ong -
    Be careful not to displace the rear camera when replacing the motherboard cover.
    Liam Ong - Ответить
    when I lifted the motherboard cover the battery cable stuck on it so that I lifted both, the plastic cover and the cable - step 4 below was not necessary to perform. Be careful!
    Rene Hommel - Ответить
    anyone know what is the 6 orange screws in step 2 are called?
    e.g. M2 x 2
    I lost some screws.
    So where can I buy some replacement of these screws?
    Tyler Durden - Ответить
  3. OnePlus One Display Assembly Replacement: шаг 3, изображение 1 из 1
    • Using a plastic opening tool, gently pry up the black plastic cover and remove it from the device.
    At the top right of your device you see a white dot. That white dot is the warranty sticker. You need to take off that sticker in order to get to the screw that lies underneath. Then unscrew that screw. Otherwise you will not be able to pry off this cover.
    Anke - Ответить
  4. OnePlus One Display Assembly Replacement: шаг 4, изображение 1 из 3 OnePlus One Display Assembly Replacement: шаг 4, изображение 2 из 3 OnePlus One Display Assembly Replacement: шаг 4, изображение 3 из 3
    • After we have removed the motherboard cover, we notice that the battery is intact and has a black ribbon attached to it, which is mounted on the logic board.
    • Using the spudger, carefully begin to lift the the battery up from the side opposite the ribbon. Be aware that there is high-grade adhesive holding the battery in its bay, so proceed with caution.
    • This battery is not encased in a hard shell so it is soft and malleable. Caution must be taken during removal so as not to cause permanent damage.
    This took a ton of force to remove from the adhesive!
    Also I was able to take off the cable before removing the battery.
    Roger - Ответить
    Is it OK to use the battery if I bent it during removal? I had to 'iron' it flat, but I think it might still be useable...
    Henry Annand - Ответить
    the best way to remove the battery is to lever the left side up from the bottom and remove it from the glue with an old credit card
    Do this! it comes up very easily this way. All the adhesive is on the right side.
    Daniel ONeill -
    Great suggestion with a card to remove the battery!
    Jeff Mack -
    Thanks for this trick saved me a lot of time
    George P -
    I second Dangerous Picture's suggestion. I found it very helpful to remove the ribbon from the dock (it was easy to do) before trying to remove the battery.
    on my phone extensive use of glue was concentrated on just one side (right hand side). Not impossible to remove, little tricky
    I mistakenly removed the battery with force, and the back peeled and brought out smoke, seemingly like it's gonna explode. Help !!!
    warys Moreno - Ответить
  5. OnePlus One Display Assembly Replacement: шаг 5, изображение 1 из 3 OnePlus One Display Assembly Replacement: шаг 5, изображение 2 из 3 OnePlus One Display Assembly Replacement: шаг 5, изображение 3 из 3
    • Once the battery has been freed, we use the ever handy black spudger to pry up and free the battery ribbon from its dock.
    • You can disconnect the battery before freeing it to make removal easier.
    For step 4, the connection to the battery should always be done as soon as possible so after removing the back plate to the board would be ideal.
    Otherwise, very thorough so far!
    Duc - Ответить
    Thought I was going to snap my battery in half but patience and slight pressure did the trick.
    Also agreeing the battery should be disconnected as soon as possible.
    Rasmus Beck - Ответить
    From where do I procure a new battery for it?????????
    Roderick Edric Chandra - Ответить
    très bon tuto ,aucun problème si vous suivez la procédure ,bravo et merci
    antoine v - Ответить
    There are several connectors to the motherboard. In the picture above, one connector above and, below the screw thread, three more connectors. Be careful to reconnect any connectors accidentally disconnected while disconnecting / removeing the battery. In my case the connector shown at the top of the row came unconnected.
    Jörg Thiesemann-Bihn - Ответить
    salut, pour moi le connecteur à la nappe était collé au cache en plastique qui couvrait la carte mère … mais le reste s’est bien passé.
    Merci pour le tuto !
    Didaf Wazir - Ответить
    Thanks Buddy, I replaced battery of my one plus one and when I switched it on, touch was not working. It was heart sinking panic moment...Then I came across https://forum.xda-developers.com/oneplus... post, simple trick of sliding piece of paper below battery solved and infact improved the touch response. Thanks !
    Radhakrishna Shetty - Ответить
    When putting in the new battery, the battery ribbon cable did not line up with the dock on the motherboard, on the replacement battery I ordered from iFixIt. I was able to carefully peel back the foil covering ribbon cable, align the cable, then press the foil back in place. Now, everything seems to be working.
    I P - Ответить
  6. OnePlus One Display Assembly Replacement, Removal of Ribbons: шаг 6, изображение 1 из 3 OnePlus One Display Assembly Replacement, Removal of Ribbons: шаг 6, изображение 2 из 3 OnePlus One Display Assembly Replacement, Removal of Ribbons: шаг 6, изображение 3 из 3
    • After the battery has been removed, use the spudger to disconnect the remaining ribbons.
    • Notice that there are two side ribbons, one on each side (volume up/down and power), and a top ribbon as well as those from the battery compartment.
    the digitizer ribbon connector has a small plastic piece that blocks the connector from being removed through the slit. make sure to remove it (simple push with an opening tool). then you can remove the connector/ribbon cable.
    Michael Jubran - Ответить
    All the ribbons came off easily after I found them, save for the volume buttons. Iended up tearing the ribbon trying to maneuver it out with the motherboard itself. Do you guys have any tips for removing the volume control ribbons? They seem to be held down by tiny extrusions in the phone.
    Crazy Joe - Ответить
    Use extreme caution with the side ribbons. I've just destroyed my Volume Buttons as I tried to get the ribbon off.
    adenoid2 - Ответить
    Another method for the side ribbons (power/volume) is desoldering the connectors - since I couldn't find any promising way to detach the buttons without damage I took this route and had success. Also note that you do not need to remove the mainboard and cameras for replacing the screen - a slight tilt should be enough to access the top ribbon (which belongs to the display assembly and has to be removed) so the side ribbons can stay in place.
    Florian Knodt - Ответить
    I removed the side ribbon for the volume buttons is really easy by using the plastic tool between the two volume buttons in direction from up (backside of the phone) to down (screen of the phone). Trying to remove it from the volume down direction end of the cable almost destroyed the volume down button, so don’t try it
    Hristo Kovachev - Ответить
    I just had to replace my screen, I skipped the removal of the side ribons and that worked perfectly. So don’t consider this step as mandatory to a screen replacement.
    Erwan Velu - Ответить
  7. OnePlus One Display Assembly Replacement, Removal of Motherboard: шаг 7, изображение 1 из 3 OnePlus One Display Assembly Replacement, Removal of Motherboard: шаг 7, изображение 2 из 3 OnePlus One Display Assembly Replacement, Removal of Motherboard: шаг 7, изображение 3 из 3
    • After removal of the ribbons, there is one final screw. Once you have removed this, the motherboard easily pries out with spudger.
    • This is the only screw that differs in size. This screw is a philips 00, 3.00 mm. in length.
    After removing the final screw that holds the motherboard in place, do not just lift away the motherboard. The antenna is fixed to the back of the motherboard in the bottom right corner. Lift the motherboard from the top, leaving the bottom part of the motherboard (the part that is nearest the battery) close to the phone body. The antenna is a black wire that runs from the motherboard around the right side of the battery recess. It is held to the back side of the motherboard by a small, round, brass-coloured connector. It can be unclipped from the motherboard using a small pair of tweezers.
    Blenk - Ответить
    There is a little tape in the battery box keep the antenna in place.
    You can remove the tape and have a few centimeters of antenna free in case you accidentally disconnect it.
    It is !&&* of a fiddeling to connect it again but it is feasible
    Jan Seidel -
    The final screw is a Phillips 000
    Jan Seidel - Ответить
    After my second assembly replacement I realised it is not necessary to completely remove the motherboard. Just lift it from the top enough to navigate the top ribbon on the assembly through the chassis and therefore avoid any possible damage to the power and volume flex.
    mlin75 - Ответить
    I encountered some resistance when lifting up the motherboard (and putting it back in later), from the corner near the sim card slot. Either because of a manufacturing defect or the plastic deforming due to age, the side of the PCB was snagging against the chassis. Got it out eventually but you have to be careful.
    John Smith - Ответить
  8. OnePlus One Display Assembly Replacement, Removal of Rear Facing Camera: шаг 8, изображение 1 из 2 OnePlus One Display Assembly Replacement, Removal of Rear Facing Camera: шаг 8, изображение 2 из 2
    • Once the motherboard has been removed simply pry off the rear facing camera with a spudger or angled tweezers.
    you don't need to remove the front or rear camera - once the motherboard is free, nothing else has to be done to it.
    fudgyhoops1 - Ответить
    The camera may fall off as the connector is pretty slack.
    You don't have to remove it but be careful not drop or lose it
  9. OnePlus One Display Assembly Replacement, Removal of Front Facing Camera: шаг 9, изображение 1 из 2 OnePlus One Display Assembly Replacement, Removal of Front Facing Camera: шаг 9, изображение 2 из 2
    • Once the motherboard has been removed simply pry the front facing camera off of its connector with a spudger or angled tweezers.
  10. OnePlus One Display Assembly Replacement, Display Assembly: шаг 10, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    iOpener
    $19.99
    Купить
    • After the motherboard and and other connected parts have been disconnected, apply heat to the screen/panel of the phone
    • We used an iOpener for this guide, but you can also use a heat gun or hairdryer for this step.
  11. OnePlus One Display Assembly Replacement: шаг 11, изображение 1 из 3 OnePlus One Display Assembly Replacement: шаг 11, изображение 2 из 3 OnePlus One Display Assembly Replacement: шаг 11, изображение 3 из 3
    • After heat has been applied use an opening pick to pry the screen away from the frame. Although a blue opening tool is preferred, you can use a guitar pick as well or similar hard plastic tool.
    • Now simply lift the screen away from the body of the phone and separate.
    • Watch it! There is i tiny frame to position the display. It is located on roundabout half the thickness of the display you see. Place the tool there to pry open or you will have to glue the positioning frame onto the phone first and then glue the display to the frame.
    New display from aliexpress does NOT have copper strips!!
    Will it work?
    PopeMike - Ответить
    I got one from e-trade-supply without the copper and it worked!
    Michael Jubran -
    Yep, the copper is just for additional an ESD ground. There are more than enough solder points on the LCD's back plate that you don't need to worry about additional ground, it's just something added in as a precaution.
    Craig Jessup -
    Thanks for the guide, sadly one of the motherboard screws on mine is stripped out... mine was dropped into a toilet, and after replacing the battery it works great, except there is very bright areas on the screen, which I'm suspecting is trapped water or something. Can you not remove the screen with the mother board in place? I'm attempting to see if I can remove the water.
    James Fox - Ответить
    be careful not to remove the plastic bezel/frame connecting the lcd to the phone body. insert the guitar pick between the lcd glass and the plastic bezel.
    Why can't you just remove the battery, disconnect the display connector and ultimately remove the screen without disassembling the whole phone ?
    Piet Petrus - Ответить
    That's actually a very reasonable question ...
    The risk of damaging or misconnecting while reassembling would diminsh substantiually !
    Stefan Van pellicom -
    Watch it!!!
    There is a tiny tiny frame to position the display. It is located on roundabout half the thickness of the display you see. Place the tool there to pry open or you will have to glue the positioning frame onto the phone first and then glue the display to the frame.
    I actually used a sharp cutter to get in between before using the pick to lift the display. works totally easy but you have to watch your fingers
    Great guide but could do with some info on reassembly, specifically how to attach the new screen. I used this
    "1mm X 50M Double Sided extremly strong Tape adhesive For LCDGlass Mobile Phone" bought from eBay for £3
    Jon Davey - Ответить
    Before I could get the top screen ribbon through the phone body, I had to remove a grey plastic filler by pushing through from the screen side. I never bothered to reattach this filler when reassembling.
    Bless you for this comment. I was just worrying about that when it popped out.
    Matt Ludwig -
    Will the new screen sit nicely on the body without glue? Can I just pop it on or do I need some glue? If so, how much?
    dhanny_101 - Ответить
    You need to buy some double sided adhesive strips/tape. I use this: https://www.banggood.com/3Pcs-Double-Sid...
    Cal Barnes -
    Bro how about the silver will strip attached to display..where will I get???
    dhananjay dhanu - Ответить
    I replaced the screen but don't get power to the screen. I briefly got striped lines but now nothing.
    Phone vibrates when turned on and i can see flashing led. But no display or light's on the navigation buttons.
    Sam Butt - Ответить
Заключение
102 участников успешно повторили данное руководство.
Javier Cruz
Участник с: 09/22/14
2 263 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 3-3, Brown Fall 2014 Участник USF Tampa, Team 3-3, Brown Fall 2014
USFT-BROWN-F14S3G3
3 членов
Автор 20 руководств
22 Комментариев
This was actually a lot easier than the guide makes it sound. I would suggest adding that you will need 1mm two sided foam tape to hold the screen in place.
Christopher Tettam - Ответить
0.o i did not know i'll need foam tape too. thanks a ton for suggestion.. i wld have just startef without tape to end up with a loose phone
vikrant1011 - Ответить
Hello
Thanks a lot for this guide.
I bought the lcd assembly from ebay and tried replacing it. But there is very thin plastic ring around the assembly which on removal is bent and seems non reusable. Now the new assembly I have bought doesnot have the plastic ring around it. How to make sure that this ring is not bent or damaged ..? I hope you are able to understand my point..:) The new replacement assembly doesnot have that thin plastic copper type ring. While removing old assembly, it comes along. Am I missing on anything ..? Thanks in advance for help
manjo3311 - Ответить
I encountered the same issue. I actually removed the entire plastic frame with the old LCD. I had to gently remove it from the lcd, clean out the glue on it from both sides and on the phone body where it sits. try to straighten it out by bending it. After that I added dual sided tape on the phone body and added the frame on to it. and then only did I manage to put more dual sided tape on the upper side in order to glue the LCD onto it. I don't feel 100% comofortable with this solution so I recommend getting a case that will cover the sides of the lcd to prevent it from falling out in case the phone falls.
Michael Jubran -
If you are wondering why the phone keeps dropping your cellular network connection, check if you forgot to reconnect either or both ends of the antenna cable. One is on the bottom side of the motherboard, lower right corner and the other is on the lower right corner of the phone casing.
Michael Christiansen - Ответить
stating to remove the buttons before pulling the board would have been nice. I now have a broken power button cable assuming that when it said "the board can be removed" it meant i had nothing else to do.
I now have a dead phone.
csbenit0 - Ответить
I made the same mistake. I came up with the following solution: http://gatlin.tumblr.com/post/1320946419...
rokenrolfeisbu -
http://www.aliexpress.com/store/product/...
I just fount a very nice seller, their LCD replacement looks nice. Now my Oneplus One is alive again, the color is bright, just looks the same as before!
Matthew Gallardo - Ответить
Are steps 7 and 8 needed if I just want to replace the screen ?
Why did you remove the cameras from the motherboard?
bhumitra - Ответить
Actually: You don't need to remove the motherboard. There is a small plastic tab on top of the motherboard, where the ribbon/connector comes around the edge. Remove that, and the other ribbon/connector for the display at the bottom of the motherboard. Turn the phone around, and remove the display.
To assemble, you need either a glue or double-sided foam tape for the display
jungelassen - Ответить
The article is good but not perfect, for example I dont need to remove the camera to replace the screen! Also I was about to commit the same mistake that csbenit0 said, this is because it wasn't included it in the guide! but luckly the power button is working.
Muhamad Alfaifi - Ответить
c spadire il mio telefono comprato da vo i il modello e ono plus one si e rotto il sispley con il vetro mi puoi inviare lindirizzo x spedirlo x ripararlo
gennaromorra1951 - Ответить
mi si e rotto il tele fono comprato da voi e un onuplus one e si e rotto il displey con il vetro e possibile darmi lindirizzo x spedirlo x ripararlo
Is there anyway to fix a broken power button?
Roni Akbas Deniz - Ответить
Skip the steps regarding removal of the motherboard. one you have removed the battery unplug the LCD and Digitizer cables, then heat and remove screen (remembering to remove plastic grommet holding digitizer cable in place).
As well as saving a lot of time this will also help people to avoid damaging the Volume/Power flexes - as this seems to be a common issue for people on here.
Whole repair took 10 minutes to complete, this guide definitely helped though so well done!
Sam Lees - Ответить
How did you fit the top LIF cable out from behind the motherboard, though? It seems the connector is wider than the hole...
ifixit3 -
i fixed the displayafter assemble the display was not working means its comeing just a litile bit of lightand vibrations only,nt working,,,whats the problem
Sai Ganesh - Ответить
Could I utilize this to replace my screen?
Becky Jesse - Ответить
Hi, Thanks for the really informative tutorial. I replaced my screen and it gives image but the thouch doesn't really work. (only in the bottom right corner and swiping) Any idea if this could be my fault in the assembly or did I just buy a malfunctioning screen?
Ronen - Ответить
I did everthing as described above. I got no indicator lights and no visual but the LCD shows backlight bleed (So the screen seems to have power but nothing else). Apparently I damaged sth. Any idea what that might be?
Christoph Kröppl - Ответить
Indicator lights are active now - maybe the battery is just really very empty?
Christoph Kröppl -
Well either the display was DOA or I damaged one of the 2 display connectors.
Christoph Kröppl -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 19
За последние 30 дней: 61
За всё время: 144,977
