Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use a hairdryer or heat gun, or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Pull the blue handle towards the hinge to disengage opening mode.
Position the suction cups near the bottom edge of the screen—one on the front, and one on the back.
Push down on the cups to apply suction to the desired area.
Push the blue handle away from the hinge to engage opening mode.
Turn the handle clockwise until you see the cups start to stretch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Insert an opening pick into the gap.
Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
Pull on the small nub on the suction cup to remove it from the front panel.
If you used an iSclack and it's still affixed to the iPhone, remove it now.
Open the iPhone by swinging the display up from the left side, like the back cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
Еще один человек закончил это руководство.
