Введение
A guide to opening up bObsweep and accessing internal parts such as: main circuit board, ground sensors, wall sensors, side brush motor, UV lamp, power switch, touch sensors, and wheels.
To reassemble bObi, refer to the closing guide. Closing bObi's Cover Post-Repair
Выберете то, что вам нужно
Remove bObi’s front wheel to access one of the screws holding bObi together.
Uninstall the larger screw that sits deeper in the wheel compartment.
Remove bObi's dustbin.
Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
Lift the brush holder. To detach completely, unplug it from bObi.
Remove the two screws on the dustbin contact point holder inside bObi.
There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
