Opening and repairing Petzl Tikka Plus 4 LED Headlamp
Выберете то, что вам нужно
    1. Opening and repairing Petzl Tikka Plus 4 LED Headlamp, Open battery compartment: шаг 1, изображение 1 из 1
      • Push the catch on the top to open the battery compartment
      Спросите у FixBot
      Добавить комментарий
    2. Opening and repairing Petzl Tikka Plus 4 LED Headlamp, Remove battery cover: шаг 2, изображение 1 из 1
      • Remove the batteries and lift the two straps with a flat screwdriver. Pull the straps out.
      Спросите у FixBot
    3. Opening and repairing Petzl Tikka Plus 4 LED Headlamp, Extract PCB and battery holder: шаг 3, изображение 1 из 1
      • This is the most crucial part. Do NOT try to release the latches at the front. Insert a small screwdriver at the positions indicated in the back near the "belt hinges" to flex the rear part of the case back and free the latches of the inner part.
      Спросите у FixBot
    4. Opening and repairing Petzl Tikka Plus 4 LED Headlamp, Disassembled parts: шаг 4, изображение 1 из 3 Opening and repairing Petzl Tikka Plus 4 LED Headlamp, Disassembled parts: шаг 4, изображение 2 из 3 Opening and repairing Petzl Tikka Plus 4 LED Headlamp, Disassembled parts: шаг 4, изображение 3 из 3
      • If all went well, the inner part should come out. In my case the push button fell into its pieces as well. You see the rubber layer and sheet metal clip of the button in the orange back of the outer knob.
      • The push button itself is a smd device of 6mm x 6mm and about 3.1mm height. The best thing would be to replace it. If you can get a spare part and can solder these tiny pads go for it. I just cleaned the dome spring with a piece of paper and reassembled it. Make sure you place the concave side of the dome spring on the three connectors.
      • Before reassembly try to insert batteries and verify that connecting the middle pole of the button to one of the outer ones switches the light on. Dont look straight into the LEDs, they're very bright!
      Спросите у FixBot
Заключение
11 человек успешно провели ремонт по этому руководству.
Toby
Участник с: 10/26/15
367 Репутация
1 руководство автора
8 Комментарии к руководству
thanks needed this.
Matt chu - Ответить Поделиться
With minor modification this guide is suitable for other Petzl torches.
Heinz de Chelard - Ответить Поделиться
How do you strap the headband after taking it off…silly question but any info would be helpful
Jeffrey Smith - Ответить Поделиться
I have a 3-LED Tikka and this guide worked the same. After many years, I was finally able to fix the screwy slider on-off switch contact with the lead on the little resistor. Whoohoo! It works fine now.
John - Ответить Поделиться
Like John, worked for 3 LED Tikka. Battery leaked all over the contacts and I was able to clean it and get it back up and running.
Jesse - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 11
За последние 7 дней: 67
За последние 30 дней: 356
За всё время: 35,011
