Opening the Hood
  1. Opening the Hood, Opening the Hood: шаг 1, изображение 1 из 2 Opening the Hood, Opening the Hood: шаг 1, изображение 2 из 2
    • Locate the hood latch beside the driver's side door, next to the left foot rest.
    • Pull the latch toward you to release the hood.
    I change my oil every 5.000 miles like clockwork I did a compression test a few weeks ago and it's only lost about 2% of it compression and done 160.000 miles so well worth it
    Graham Wells - Ответить
    What if u can’t get inside to unlock the hood
    Paula Charron - Ответить
    My fob is not working properly I guess I checked the battery and it’s good still won’t open car a Sonata hybrid 2021 what do I do?
  2. Opening the Hood: шаг 2, изображение 1 из 2 Opening the Hood: шаг 2, изображение 2 из 2
    • Walk around to the front of the vehicle.
    • Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
    • Once the tab is released, lift the hood up.
  3. Opening the Hood: шаг 3, изображение 1 из 2 Opening the Hood: шаг 3, изображение 2 из 2
    • Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
    • Place the tip of the hood stand into the hole located in the upper left of the hood.
    • You can now let the hood rest on the stand.
Заключение
4 участников успешно повторили данное руководство.
Shaun MacDonald
Участник с: 10/03/12
2 558 Репутация
Автор 8 руководств
Команда
Cal Poly, Team 24-27, Regan Fall 2012 Участник Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 членов
Автор 22 руководств
Один комментарий
Whats next after opening the hood? How to check for the hood latch? Where is it located? Need to check for the cause why the alarm keeps going
off at odd hours. The car has lojack and a car alarm. Changed the FOB key that didnt worked. Manually opened the door with key. Not happening problem still exist. Need help with what other options.
boomanison - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 36
За последние 7 дней: 330
За последние 30 дней: 1,455
За всё время: 46,569
