Введение
The Oppo R9m walks like an iPhone, looks different inside, but scores like an iPhone, too.
Запчасти
Детали не указаны.
  1. Oppo R9m Repairability Assessment, Oppo R9m Repairability Assessment: step 1, image 1 of 3 Oppo R9m Repairability Assessment, Oppo R9m Repairability Assessment: step 1, image 2 of 3 Oppo R9m Repairability Assessment, Oppo R9m Repairability Assessment: step 1, image 3 of 3
    • Exterior reference shots.
  2. Oppo R9m Repairability Assessment: step 2, image 1 of 2 Oppo R9m Repairability Assessment: step 2, image 2 of 2
    • T2 Torx screws appear to secure the display, but removing them doesn't seem to make its removal any easier.
    • Very strong clips secure the interior of the phone to the stiff metal rear case.
  3. Oppo R9m Repairability Assessment: step 3, image 1 of 1
    • Nothing on the rear case.
    • Battery immediately accessible.
  4. Oppo R9m Repairability Assessment: step 4, image 1 of 2 Oppo R9m Repairability Assessment: step 4, image 2 of 2
    • Battery pull tab has instructions and works well to peel the battery up. Adhesive is fairly stiff.
    • Battery takes protective sheet with it, revealing interconnect cables.
  5. Oppo R9m Repairability Assessment: step 5, image 1 of 1
    • After the battery the next available components are:
    • Antenna interconnect cables.
    • Charging port and cable, very good for repair, individual part, and easily accessible.
    • Various brackets, annoying for reassembly, but standard Phillips #00 screws are a bonus.
  6. Oppo R9m Repairability Assessment: step 6, image 1 of 2 Oppo R9m Repairability Assessment: step 6, image 2 of 2
    • The motherboard-daughterboard interconnect cable connects to the underside of the daughterboard, which makes removing the cable or board more difficult.
    • The headphone jack is soldered to the daughterboard, but the board is small and has minimal parts, so it should be an inexpensive replacement component.
  7. Oppo R9m Repairability Assessment: step 7, image 1 of 2 Oppo R9m Repairability Assessment: step 7, image 2 of 2
    • Motherboard and speaker assembly are now removable.
    • Once the motherboard is removed the following components can be removed: camera bracket, cameras, interconnect cable.
  8. Oppo R9m Repairability Assessment: step 8, image 1 of 1
    • The display assembly final components are fairly easily removed: home button bracket, home button, button cables, vibrator, earpiece speaker.
    • Including the frame and fused display in the display assembly makes the part more expensive.
  9. Oppo R9m Repairability Assessment: step 9, image 1 of 2 Oppo R9m Repairability Assessment: step 9, image 2 of 2
    • The Oppo R9m earns a 7 out of 10 on our repairability scale (10 is the easiest to repair):
    • Battery is fairly easily accessible and removable.
    • Most components are extremely modular making for cheaper repairs.
    • The opening procedure is extremely tough, clips are very stiff and likely to be broken.
    • The single unit display assembly is annoying to reach, and will be a costly part.
    • Manufacturer does not provide user-accessible repair documentation.
Финишная черта
18 участников успешно повторили данное руководство.
Sam Goldheart
Участник с: 18.10.2012
452 396 Репутация
Автор 548 руководств
Команда
iFixit Участник iFixit
Community
145 членов
Автор 15 566 руководств
Комментариев: 3
need stuff like pin unlock etc
callgoldengaia - Ответить
Can I get the mother board of oppo a37
Aryan Bunde - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 34
За последние 30 дней: 194
За всё время: 7,903
