Oppo X9000 Power Button Replacement
Выберете то, что вам нужно
  1. Oppo X9000 Power Button Replacement, Removing the Back Cover: шаг 1, изображение 1 из 2 Oppo X9000 Power Button Replacement, Removing the Back Cover: шаг 1, изображение 2 из 2
    • Turn the phone over so that you are facing the back side of the phone.
    • With your fingers, pry the back cover up starting from the top of the phone near the headphone jack and camera.
    • Completely remove the back cover by moving down the sides and bottom with your fingers.
  2. Oppo X9000 Power Button Replacement, Removing the Battery: шаг 2, изображение 1 из 1
    • With your finger, remove the battery from the phone by gently lifting the top-right corner nearest to the camera.
  3. Oppo X9000 Power Button Replacement, Remove the Back Panel Screws: шаг 3, изображение 1 из 2 Oppo X9000 Power Button Replacement, Remove the Back Panel Screws: шаг 3, изображение 2 из 2
    • Remove the twelve exposed 3.6 mm Phillips screws on the rear of the phone using the 3.6 mm Phillips screwdriver.
    • Store all the screws in a safe place where you will not lose them.
  4. Oppo X9000 Power Button Replacement, Remove the Rubber Stoppers: шаг 4, изображение 1 из 2 Oppo X9000 Power Button Replacement, Remove the Rubber Stoppers: шаг 4, изображение 2 из 2
    • Remove the three circular rubber screw covers on the back of the phone by slipping the spudger into the border between the rubber cover and the chassis. In one motion, pry the stopper out of the hole. This can take some force.
  5. Oppo X9000 Power Button Replacement, Remove the Newly Exposed Screws: шаг 5, изображение 1 из 1
    • With the 3.6 mm Phillips screwdriver, remove the three newly exposed 3.6mm Phillips screws.
  6. Oppo X9000 Power Button Replacement, Lift off the Back Panel: шаг 6, изображение 1 из 2 Oppo X9000 Power Button Replacement, Lift off the Back Panel: шаг 6, изображение 2 из 2
    • Insert the plastic opening tool underneath the chassis near the power button and pry the chassis from the phone. This should take a little force.
  7. Oppo X9000 Power Button Replacement, Remove the Power Button Bracket: шаг 7, изображение 1 из 1
    • Use the sharp end of the spudger to pry the power button bracket from the side of the rear case.
  8. Oppo X9000 Power Button Replacement, Let the Button Fall Out: шаг 8, изображение 1 из 1
    • Rotate the phone onto its side so that the power button falls out with ease.
    • Make sure not to lose the power button.
Заключение
4 участников успешно повторили данное руководство.
Joe Hanacek
Участник с: 10/14/14
526 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 4-45, Amido Fall 2014 Участник Cal Poly, Team 4-45, Amido Fall 2014
CPSU-AMIDO-F14S4G45
5 членов
Автор 11 руководств
Один комментарий
I am having trouble with my buttons as they no long spring back after i replaced the speaker. They now just sit flush with the body of the phone, both buttons and metal brackets are installed.
Any ideas?
Jake Karp - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 3,663
