Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Pre-req for removing the faceplate from Optical Bay Enclosures #78, 79, 80
Выберете то, что вам нужно
Remove the three 3.0 mm Phillips screws from the optical bay enclosure.
Starting from the left edge, gently pull open the optical bay enclosure.
Continue to pull open the two halves of the enclosure until they separate.
Remove the two 3.0 mm Phillips screws securing the faceplate to the optical bay enclosure.
Lift the black plastic faceplate out of the optical bay enclosure.
Reassemble the optical bay enclosure without the faceplate, reusing the original three 3.0 mm Phillips screws to keep it intact.
