Введение
Electric toothbrushes are powered by a rechargeable battery, that enables the reciprocating brushing motion of the bristles. If your electric toothbrush loses power quickly or doesn't hold charge, most likely the rechargeable battery needs to be replaced.
Выберете то, что вам нужно
Pull off head, and use pliers to remove the white cap. Pull out the circuit core.
De-solder in these four (4) locations.
The two (2) motor connections
The Positive (+) side of the battery
The Negative (-) side of the battery
De-Solder lower battery connection terminal. Bend back battery terminal to clear circuit board.
Use plastic prying tools to carefully pry off the circuit board. (Utilize metal spedger as a last resort)
Pull the circuit board and battery assembly out. Then proceed to remove the battery from the circuit board
To reassemble your device, follow these instructions in reverse order. Remember to apply just enough solder to re-attach the terminals.
15 участников успешно повторили данное руководство.
8 Комментариев
This is very easy to do. I had no problems following your instructions.
Thanks.
Is this a regular rechargeable AA?
Thanks again.
The original battery is a NiCd with tabs. I just spot welded tabs onto a standard AA NiMH battery and it worked fine.
T C -
@stephen Shaw These batteries worked for me: https://www.amazon.com/dp/B00CR0R8KQ/ref...
