Введение
Electric toothbrushes have one or more O-rings to prevent water from entering the handle and damaging electric parts in the handle. If the O-ring wears out, you'll see water seeping through the handle during use.
Выберете то, что вам нужно
Using the pliers, rotate the head base 90 degrees counterclockwise and remove core from the handle.
Еще один человек закончил это руководство.
