Введение
Electric toothbrushes are powered on by a small on/off switch located on the outer case of the toothbrush handle. The on/off switch signals the circuit board to power the motor. If you press the power button and the toothbrush doesn't power on, most likely the power button needs to be replaced.
Выберете то, что вам нужно
Using the pliers, rotate the head base 90 degrees counterclockwise and remove core from the handle.
Desolder the 4 terminals and remove the old button.
Remove as much of the old solder as possible.
8 участников успешно повторили данное руководство.
4 Комментариев
Before unsoldering the button, you can understand if it is good or not just bypassing it with a wire: with a copper wire you can touch two pins of the button (one on the right side, on on the left side); if the toothbrush starts and stop on each touch of the wire, the problem is the button. I recognize the problem in this way.
True except if the switch is permanently “on”. I think that was my case. Replacing the switch fixed the issue.
