Выберете то, что вам нужно
There is a border between the black phone backing and the silver screen.
Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
When the halves are parted correctly, the gap should look like this.
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
Инструмент, используемый на этом этапе:Tweezers$3.99
Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
There is a black flap on the bottom of the battery.
Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
Remove the anti-static wrist strap.
Use the Phillips #000 screwdriver to remove the five black 2 mm screws.
Use the Phillips #000 screwdriver to remove the two grey 2 mm screws.
Use a pair of angled tweezers to remove the speaker housing.
